Wyze Sense Climate Sensor
Requires Wyze Sense Hub. This device will NOT function as an individual or standalone product or with Wyze Sense v1.
Place Wyze Climate Sensor in any room to track temperature and humidity throughout the spaces in your home with the Wyze app. With a 500 ft range, easily position it in distant rooms, basements, or attics. Wyze Climate Sensor is designed to be unobtrusive with a sleek, white design to blend into any environment. Set it on any surface or use the peel-and-stick adhesive backing for walls.
No, these sensors are not standalone products and must be paired with a Wyze Sense Hub to function. Need a Wyze Sense Hub? Check out the Wyze Home Monitoring Core Starter Kit.
No, but the leak and climate sensors will not work without the Wyze Sense Hub (available with a subscription to Wyze Home Monitoring). If you have a hub but no active subscription, you will still be able to use your leak and climate sensors.
No, these sensors are incompatible with Wyze Sense v1. They must be paired with a Wyze Sense Hub, found in the Wyze Home Monitoring Core Starter Kit.
The range is up to 500 feet in ideal conditions. Please keep in mind that walls and other interference between the sensors and hub may decrease this range.
Yes, but the accuracy of the sensors will be decreased and it is not recommended.
No, these sensors are for indoor-use only.
No, not right now. In the future, Wyze Thermostat will be able to run your HVAC system based on temperature data collected by the sensor. That feature is in development.
You'll be able to set notifications for temperatures between 32-104º F (0-40º C) and humidity from 0% to 85%.
