10.5mm audio drivers deliver bone-rocking bass from lace up to cool down.
Wyze buds are engineered to deliver an intensified, bass-driven sound to help propel you toward your fitness goals.
Choose the perfect fit so you can keep moving.
Up to 27 hours of charge. Guaranteed to outlast almost any workout.
With up to 7 hours on a single charge plus 20 hours in the case you get battery life so long your play button might get tired.
4.8 grams of lighter-than-air comfort.
These truly wireless earbuds offer a comfortable, barely-there feel and a low-profile design that isn’t desperate for attention.
Keep moving with phone-free touch controls.
Keep the interruptions to a minimum with customized smart touch controls that don't skip a beat. Tap twice to play/pause. Tap three times to activate the voice assistant.
More smart features. Wear detection for hassle-free stops and starts
An embedded sensor auto-detects when it’s in your ear and knows what to do when it’s not.
IPX5-rated moisture resistance can withstand sustained perspiration from crossfit to marathons and everything in between.
Tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose selections that are optimized for music, movies, voices, gaming, and more.
A 4-microphone system let's you hear the world around you with a simple touch.
Instantly connect to Amazon Alexa to play your favorite music, check the weather, get news, and more. Wyze Buds are also compatible with your phone’s native smart assistant (Siri, Bixby, Google Assistant).
* Optimized for Android. iOS requires the Alexa app in the background.
Wyze Buds
-30 dB passive noise reduction
-Up to 27 hrs of battery life
-4-microphone system
