Skip to content
(Refurbished) Wyze Cam Outdoor v2
Style
The best wireless outdoor cameras made by Wyze, with a starter bundle. A great add on to your home security systems.
Starlight. Color Bright.
Unedited footage. Shot on Wyze Cam Outdoor v2.
See in extraordinary detail at night.
Placeholder Image Placeholder Image
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
IP65 Weatherproof
Bring on the downpours, blizzards, and heatwaves. Wyze Cam Outdoor v2 is built from the ground up to be a workhorse in even the harshest conditions.
  • Dust Tight
    Guarded against dust and other particulates
  • Waterproof
    Protection against low pressure jets of water
  • Extreme Heat/Cold
    Fully functional in climates of -4° up to 122°F
1 of 3
Now with an even wider field of view.
Our new lens maximizes viewing angles while tampering distortion so you can see more of your property without compromising on the details.
Placeholder Image
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
With up to 6 months of battery life...
Mount wherever you need it, without worrying about running wires or finding outlets. Two integrated rechargeable 2,600 mAh batteries last up to 6 months on a single charge.
...and continuous charging with Wyze Solar Panel.
Every superhero needs a sidekick. Wyze Solar Panel converts sun rays into power so you can leave your camera up longer with less frequent charging. With enough sunlight, you may never need to take it down again.
Get notified when motion is detected...
Wyze Cam Outdoor v2 uses passive infrared sensors (PIR) to sense body heat signatures to reduce false alerts from things like waving branches. When motion is detected, you'll get an alert sent straight your phone, so you never miss a thing.
...and respond in real-time with two-way audio.
Ask the delivery person to hide a package behind the bushes, or scare off unwanted guests in your yard using the built-in siren.
Record up to 56 days of video with a 256GB Wyze microSD Card.
Get approximately 56 days of SD video and 16 days of HD video.
Level up with Cam Plus for $1.66/month
Unlock premium features that make your already great Wyze Cams even better.
• Unlimited Full-Length Video Recording
• Smart AI Person/Pet/Vehicle Detection
You'll even get exclusive subscriber discounts on Wyze products!
Learn more
Travel Mode
Staying at a hotel or backpacking in the Rockies? Travel Mode lets you record motion & time-lapse videos to a microSD card (sold separately), even when you’re not connected to the internet or the base station.
The Wyze app is your command center.
Drop in anytime, from anywhere to view live video feeds.
Get glanceable insights into what your camera is seeing in the Events tab. See quick labels of who or what caused the Event with Cam Plus.
It's easy to install Wyze Cam Outdoor v2
Nervous about installation? We get it. Just watch our step-by-step installation video below to see how easy the process actually is.
