Wyze Watch 47c
Wyze Watch 47c
Testing SelectLink()
Buy one, get one 30% OFF
Applies automatically. See terms.
No se pudo cargar la disponibilidad de retiro
- Wyze Watch 47mm C comes in 4 total colors: Rainbow, Space Blue, Classic Blue, and Classic Black.
- It has new packaging specially designed for the holidays.
- It comes with 12 new and exclusive watch faces.
No, the firmware is the same as the original Wyze Watch 47mm. There are no new functions.
No, individual straps for this version are not available. Because of limited quantities, the straps are sold exclusively with Wyze Watch 47mm C.
- Classic Black: Black frame with a black silicone strap.
- Classic Clue: Light blue frame with black silicone strap.
- Space blue: Dark blue frame with blue nylon strap.
- Rainbow: Purple frame with rainbow nylon strap.
No, the new watch faces are exclusive to Wyze Watch 47mm C.
No, it uses an included magnetic charger and does not work with wireless chargers.
You can accept and deny incoming calls using your Wyze Watch, which works great if you’re wearing Wyze Headphones or Wyze Buds. However, Wyze Watch does not have a built-in microphone or speaker.
No, it does not support contactless payments or NFC.
No, it does not support cellular data or GPS. It works via Bluetooth-only.
Silicone for Classic Black and Classic Blue, Nylon for Space Blue and Rainbow.
It stands for both Color and Classic. Maybe we should call it C².
