Ir directamente al contenido
1 de 3
Wyze Scale
Wyze Scale
$27.80
Agotado
Agotado
Scale up your smart home
Ver todos los detalles
Measure more than just weight
Health is measured by more than just weight. Wyze Scale also measures body fat, lean body mass, and even your heart rate. With 12 metrics tracked, you get a full picture of your health.
See it all in the Wyze app
Wyze Scale shows you weight and body fat percentage on a crisp LED display, but inside the Wyze app, you can get an even better picture. See your weight and body composition trends over time. Track your progress. See yourself succeed.
Syncs with popular fitness apps
Wyze Scale connects with popular fitness apps so you can track your progress where you are tracking everything else.
Auto-recognition and sharing
Wyze Scale is meant for sharing. Set up your family in the Wyze app or share it with an unlimited number of friends. It can automatically recognize up to 8 users and has a guest sharing mode that lets you share with anyone.
More reasons for you to step on it
Heart rate tracking
Wyze Scale goes beyond body composition - Step on, see your heart rate, and track heart health over time in the Wyze app.
Step anywhere
Accurate and easy measurements no matter where you step. Wyze Scale uses four independent floor sensors that measure to the 10th of a pound. It has a network of electrode sensors built right into the glass that accurately measure no matter where your feet are.
Turns on when you step on
No more annoying “tap and wait” before stepping on. All you do is step on and Wyze Scale immediately starts measuring.
Syncs automatically
Wyze Scale keeps track of all your measurements and then automatically syncs via Bluetooth when you open the Wyze app.
From unboxing to measuring in minutes
  • 01
    Install the batteries and place the scale on a hard floor
  • 02
    Download the Wyze app and add the scale as a new device
  • 03
    Step on and start measuring
