Wyze Light Strip
Wyze Light Strip
16 million colors for every corner
Add a splash of color to backlight your favorite screen, frame your headboard, or illuminate dark corners. Just peel, stick, and plug in Wyze Light Strip anywhere for perfect accent lighting.
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
More bright ideas
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
Explore Wyze Light Strip Family
Wyze Light Strip (Current Page)
- One color per strip
- Basic lighting effects
- No epoxy coating -
Wyze Light Strip Pro
More Info- Up to 16 colors per strip
- Advanced lighting effects
- Protective epoxy coating
- Plus all great features of Wyze Light Strip!
