Wyze Air Purifier
Wyze Air Purifier
The products featured on Negotiated by Wyze do not integrate with Wyze devices or the Wyze app.
These products are manufactured by unaffiliated companies, but are shipped by Wyze. Wyze may receive a commission, at no additional cost to you. The devices are not eligible for Wyze's Return Policy and Limited Warranty Terms. However, damaged or defective products will be replaced by Wyze. Please reach out to our support team in this situation. For product specific assistance, please reach out directly to the manufacturer.
Clean, healthy air for everyone.
The power supply of the Wyze Air Purifier is AC 120V / 60 Hz. In other areas outside of the US and Canada, a voltage converter may be needed. Some app features such as outdoor air quality monitoring may not be available outside of the US and Canada.
We recommend running your Wyze Air Purifier continuously to circulate the air and reduce the air pollution level. In a home with an HVAC system circulating air, the air coming out of your vents will be significantly dirtier than the air in the room with the air purifier, especially considering most homes rarely have their air duct cleaned. Wyze Air Purifier is energy efficient and quiet when the pollution level is low, so you can keep your air clean 24/7.
Wyze Air Purifier is CARB certified which means it does not exceed ozone emission limits. Our units do not use any ionization-based components which could generate harmful byproducts.
Wyze Air Purifier (regardless of the filter equipped) is designed to remove both particulate and gaseous pollutants that are commonly found at home, including dust, pollen, mold, pet allergens, viruses & bacteria, volatile organic compounds (VOCs), odors, and tobacco smoke.
Wyze Air Purifier comes with three interchangeable options. Wyze Air Purifier with Allergen filter is considered to be sufficient to handle common pollutants found in most homes. The wildfire filter is particularly effective against smoke generated from wildfire, industrial processes, and traffics. The formaldehyde filter is designed to be extra efficient for removal of harmful gas such as VOCs and formaldehyde. They are commonly found in household products, e.g., cleaning agents, paints, varnishes, furniture, and wax, and generated in activities such as cleanings, applying cosmetics, and smoking. The formaldehyde filter is recommended for homes with smokers, new constructions or remodeling, or new products such as new furniture.
It’s tempting to think we are safe from the dangers of air pollution when in the sanctity of our own homes. However, however indoor air is on average 4x to 5x more polluted than outdoor air according to the US EPA. Outdoor air will travel inside at certain times, and local allergens and auto emissions will also make their way into your home and become trapped due to poor ventilation. We recommend using air purifiers for short-term and long-term health benefits regardless of your home distance from outdoor pollution sources.
Once you subscribed to our Wyze air purifier filters on Wyze.com, Wyze will ship one filter of your choice to you every 6 months with a 10% discount.
The filter life and performance could vary depending on usage and your home environment. In general, we recommend replacing your air purifier filter at least every 6 months to maintain the best performance. Your Air Purifier app will let you know when it is time to replace the filter.
If you only have one air purifier, the ideal place to put the air purifier is the room in your home where you spend the most time out of each day. For most people, this will either be your bedroom or living room. Try to keep your unit at least 1 foot away from walls or furniture and avoid blockage of air entrance and exit vents. This will allow air to circulate properly and the air purifier to operate more efficiently.
Wyze Air Purifier is effective in rooms up to 452 sq. ft (42 m2). For slightly larger rooms, you can run the unit at a higher fan speed for longer periods of time to achieve the same cleaning performance.
